Anyone have a source or a part number for a fuel pump kit for a 23HP Kohler command engine, would like to keep my valve cover
Since we don't have a Kohler or Cub Cadet Model Number, it is hard and would only be a guess.
My experience has been you need to buy a replacement pump which includes a new valve cover. They are readily available.
Same here.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
Yeah OK thanks by the way it's a 3235
Don't see the use of buying a complete valve cover assembly when it has a simple diaphragm |
Not much use to it then.
I've never seen a kit for them, other than the one that comes with a new valve cover and new pump. I just replace them with a vacuum pump.
JD x475 |
Try part number KH-24559-08-s that is Cover Kit - Fuel pump valve
Oz
My wife says I do not listen , at least I think thats what she said |
| Thread Tools | |
| Display Modes | |
