Wow, that's a really bad repair job... what's keeping that bolt from coming out and putting your eye out?
1872 with 50C deck 1862 with 50C deck 1641 with 48GT deck 364 snow blower IH Cub Original with deck GREEN 317 with integral sleeve hitch, front hydraulic |
I have a like new clutch disk you can have for $20.00 plus the shipping. I'll get some pics a little later.
Thanks, looking forward to the pics. Much appreciated.
2005 CC GT2544 1980 IH CC 782 1957 Cub Lo-Boy 1993 Craftsman LT4000 |
Pics of the clutch disk
Looks like the 6.5" version all right. Thanks very much, I'll message you my email address and you can send me the total with shipping and how you prefer payment. Again, much appreciated. Now I have to see if there's any chance of saving the pin disc.
Looks like the "Drive studs" are still available. Cub as expected is stupid expensive, the want $150 for 3 of them. This is a google search
https://www.google.com/search?channe...cadet+911-3043 Screen shot of the Cub price. I bet JeffinPA could whip up a few with no problem.
Yeah, I saw those dealer prices. Kind of crazy. I'm sure I'll be contacting Jeff, and here's within driving distance!
This beauty has a slight modification to the clutch pedal return spring connection and just a bit of wear on the pivot pin. What's strange is someone went to all the trouble to replace the clutch release lever but not the pin.
Next question, how do you get the driveshaft out? It seems to have a pilot at both ends and someone stuffed 2 rag joints in the back end so it is real tight. I have everything disconnected and it's not moving. What's the secret? Do I have to knock out the roll pins?
I slide the engine forward. 6 bolts and the engine plate will slide forward plenty to get the shaft out. You will need to pop the spirol pin out to get the shaft out unless you want to remove the rag joint bolts.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
| Thread Tools | |
| Display Modes | |
