Old 06-08-2022, 05:36 PM
john hall's Avatar
Default 1811 front tires
My presumably original front tires are done. This mower never does anything but cut grass, however it gets put in some very hilly places thanks to loaded rear ag tires. I’ve seen the front try to slip a bit on turns on hills. Would you stick with turf tires or is there something that has more bite but doesn’t tear up the lawn?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 06-08-2022, 07:08 PM
Farmall450's Avatar
I would use good turf tires -- Carlisle Turf Master or Multi Trac C/S
Old 06-09-2022, 08:11 AM
fortyeightjake's Avatar
fortyeightjake fortyeightjake is offline
I wonder if V61's would give you a little more side bite. I have a pair waiting to go on but haven't got around to it yet.
Old 06-09-2022, 08:25 AM
Sergeant's Avatar
Sergeant Sergeant is offline
The V61 Give Him better steering control. But Bite for steep Hills a new set of Turfs will do that better then the V61. All My Cub Garden tractors Have V61 On the front except for Original, 70 and XT3GSX But Probably the Best for Not sliding On Hills sides would be this https://www.millertire.com/16x6-50-8...ac-4-ply-tire/ and they won't tear up the turf
Old 06-09-2022, 01:23 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Arrow
I used these:
https://www.ebay.com/itm/363595386505
Old 06-09-2022, 05:43 PM
Farmall450's Avatar
Originally Posted by 1711Cub View Post
For that price you can basically get Carlisle Turf Masters, which those are a knockoff of.
Old 06-09-2022, 07:51 PM
1711Cub's Avatar
Lightbulb
Cheapest Carlisles were $46 each. These were $35. They mounted up well and hold air well without tubes. We shall see how long they last before they dry rot.
Old 06-09-2022, 09:19 PM
Radioguy41's Avatar
Radioguy41 Radioguy41 is offline
I put a pair of tri-ribs on my 782. About $65 with tubes. They don't tear up the lawn, no side skid, and steer like power steering.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
1993 Craftsman LT4000
Old 06-09-2022, 11:46 PM
Farmall450's Avatar
Try Walmart's website or Farm & Fleet if you have any nearby. Turf savers for 982 fronts were less than that when I quoted them 2 weeks ago
However, I'd go with the Turf Master or Multi Trac
