I was over at my grandmother-in-law's place today doing some weed trimming. It's a fairly large lot with lots of trees and fences to trim around. After about an hour of solid work, I shut off the trimmer to change the line. Went to crank it back up and it would idle but shut off when I gave it the throttle. After I let it sit for a good 30 minutes, it worked fine again. So I assume it overheated?
This doesn't seem to be just this particular trimmer, as I had a different one the last time I did this at her property. Except that trimmer overheated after only 30 minutes of runtime. Is there a good way to keep these things cool? Or is it just the consumer grade equipment isn't meant for long sessions, and I should get a commercial grade unit? |
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
Echo is the same brand my local repair shop advertises as well. Maybe once my Cub Cadet trimmer dies (which I got for free btw), I might look into a professional grade trimmer.
ECHO makes a premium product in Lake Zurich, IL. And, they have a 5 year consumer warranty.
Sounds like vapor lock. Carburetor gets hot when shut down because there is no fuel and air flow to cool off. Try idling a moment before hitting kill. If that doesn't work, consider richen the mixture a little to run cooler.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
I'll try the idle trick. This trimmer calls for 40:1 ratio, which is what I've been using in it (the premix canned stuff).
Have a look at how much oil is in a 40 to 1 mix and you expect that to provide good lubrication and cooling , I have been using 25 to 1 mix with no problems also no smoke as the motor is pretty much always running at peak RPM
Some will de-cry my usage but the advice came from some one who makes a living working on small engines , not a hobbyist Oz
My wife says I do not listen , at least I think thats what she said |
| Thread Tools | |
| Display Modes | |
