The good news is, the flywheel came off this afternoon.
![]() The bad news is, all the magnets on the back side of the flywheel, became loose, from using that BFH. ![]() Now, does anyone know of a satisfactory adhesive to re-glue these magnets back on ??
2 part epoxy "steel weld" by Permatex. works for me.
As you prolly know from watching "Terrell fixes all" do keep the north/south orientation in mind as you reattach the "maggots" as well as the spacing. Clothes pins keep the spacing equal and careful clamping of the Maggots so they don't break using vice grips gingerly, while the epoxy dries. clean everything carefully and marking the magnets er "maggots" ![]() avoids any errors in N/S magnetism. in the event the the orientation is not followed, it will not put out max output, if at all.
If you have been lucky, none of the magnets have been destroyed or cracked. I have always had success, regluing them with no problems, using JB Weld and it is not hard to figure out where they go because of markings or rust spots on the inside of the flywheel. But the tricky and most important part is that going around the circle, the magnets must align, end to end, north to south, all the way around. In other words, if you rotate one of the magnets and glue two in with a south pole facing a south pole, and/or a north to north, it may give a charge but not a full charge. Somewhere on the net, there is a diagram or a video explaining this but I don't have it right now. I'll repost if I find it. |
Here ya go Roland....
https://www.google.com/search?q=repl...awbkP7_uauAQ21 |
YUP, watched that video.
I just used the original JB Weld on my 682's magnets with great success.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
+1 on JB. That's what I used on my M20 flywheel also.
While sorting the Magnets for "attracting" or "repelling" one of the magnets is broken. Clean break. Question is, is that magnet toast, or put the break line together, and glue it in?
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
| Thread Tools | |
| Display Modes | |
