Pulled a sleeve hitch off a 1650 parts tractor for my 1811.
Believe I still need to make or buy the straight lift rod and rod mount.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
Mowed (for real) with the 2182 super for the first time. Ran good for an hour. Does seem a little light on power considering it only has the 48 GT deck, but the grass was pretty thick and slightly wet.
Cleaned up the 984 and changed the engine oil/filter. Cleaned carb & replaced fuel filter. Runs good!
Last night I acquired some 23x10.50-12 Goodyear Terra-Tire (R1) for my y/w 782, and mounted up a turf master on the front to match the RHS.
Hoping to get the carb rebuild and on this week and see if she runs. If so it's getting the sleeve hitch in time to cultivate some headlands before the crops get too big.
Had the 100 running for the first time in a few years. After draining the nasty gas and putting fresh in she fired right up. Then is was time for a long overdue ride. My oldest boy can finally reach the clutch.
Finally pulled the trigger on a set ag’s for the rear. Feels much more sure footed now. Maybe add fluid next?
First mow with the 984 yesterday. Put the rest of the tin and hood back on last night and am going to finish up mowing today.
| Thread Tools | |
| Display Modes | |
