#21
FWIW:
The the fuel shutoff solenoid does multiple things beside helping to eliminate soiling yer britches when it backfires. ![]() The EPA had a hand in it to prevent raw fuel from entering the combustion chamber, adding about as much pollution as a flea fart. Also it tends to prevent "dieseling" which is the engine continuing to run-on, after the spark is stopped because the combustion chamber is hot enough to cause ignition (usually called preignition) So now you know all the reasons for it. Its a good device when it works
#22
I guess I have been fortunate with all of my older machines. None of them have ever backfired after a shutdown. Of course, I idle all of them down for a brief period before shutting them down. It's a short cool down. It's the little things like this that make the difference. Also, I engage the electric PTO's at a low engine speed, then place the engine to full throttle to mow.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
#23
#24
I worked the 1712/1812 for about 3 hours today. It didn't have a hiccup at all.
I do need to back the idle screw out, just a touch though. Tomorrow, I'll run it for a few minutes, then do another oil change. Then it will be ready for normal duty.
Original OCC Super Mod....and former OCC Co-Admin. I was hacked........ |
#25
I'm thinking this one is gunked up, from sitting for 3 years or so.
#26
As you know, I have a 782. I have run both the Kohler and Walbro adjustable Carbs. Although the Walbro adjustable is better than the Walbro fixed jet, I'll take a Kohler (Carter) any day.
#27
![]() Beats a manual shutoff for accessibility, though.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
#28
From a little 2 hp Briggs, to the larger 4 barrel carbs on cars/trucks. Simple and effective. I've been around them since the 50's
#29
I worked the 'ol girl for about 1.5hrs tonight. Brought her inside and gave her a compressed air bath. Then did a oil and filter change......the second one in less than 5hrs of use.
I changed the oil and filter before I started it the first time Saturday. And it was already very black, so it might take a few changes, to get the M18 cleaned out.
| Thread Tools | |
| Display Modes | |
