Old 11-02-2022, 03:33 PM
If the tank has varnish and such in it, I find lacquer thinner or acetone will dissolve it, but it will take time.
I guess I missed the part where it was mentioned it had "varnish" type deposits.
Acid does better on metal not a "varnish" situation.
It will eventually work in the varnish, but prolly eat the tank also/first.
I wish you luck they can be difficult to clean but they are so small compared to a 20 or so gallon vehicle tank.
Old 11-02-2022, 05:55 PM
farmer52 farmer52 is offline
In addition to varnish, there is rust (at least looks like it). Perhaps I should try lacquer thinner THEN Muriatic acid.
Ken
Old fart - new to Cub Cadets
Looking for a nice original low hour 1772 or 1782
Old 11-02-2022, 07:08 PM
Gary C Gary C is offline
I've been using vinegar for rust removal, it works slow, but it does the job. For varnish and paint removal, lacquer thinner is my go to. I've soak carbs in it numerous times. ( tryclorethelene use to be the best, back in the day)
Old 11-02-2022, 07:59 PM
ironman's Avatar
ironman ironman is offline
Originally Posted by farmer52 View Post
Interesting video. At least my tank does not leak so no concern about resealing. I just need to get the rust and "crap" out of the inside.
If the tank has a baffle I don't want to be adding gravel or small objects.
Perhaps you misunderstood the concept which is not only to seal leaks but also to coat the inside of the tank with a lining that seals the rust and crap away forever and is impervious to anything that you might put in there. Again, not promoting, just trying to help.
Other videos on that website about sealing "motorcycle" or sub-5 gallon tanks may be more informative. Granted, the kits they sell are expensive but so are old used K Series Kohler gas
tanks.
Old 11-02-2022, 08:28 PM
tanks.
Thanks for the clarification. My goal at this time is to get it running.
Ken
Old 11-03-2022, 06:29 AM
Unhappy
Found out this morning why the hydro release lever does not function properly. The "extension" outlined is broken off (missing) from the drive line cover mechanism.
Photo courtesy of 'the auction site'
Ken
Old 11-03-2022, 07:14 AM
IHCubCadet147's Avatar
That is pretty common for them to break. You can just hold down the two release buttons by hand to push the tractor, providing they are not stuck from sitting.
Old 11-03-2022, 07:51 AM
Oh boy....weak link. I can't hold down the buttons and pull it out of the confined area by myself. That is why I am trying to get it running so I can drive it out. At least that is my plan.
What is a reasonable price to pay for a good used cover/lever assembly? How difficult to find? Doesn't look like an easily repaired item.
Ken
Old 11-03-2022, 09:03 AM
No need to buy the complete setup.
Charlie at CCS, up top, will have just the flapper.
Easy fix
Old 11-03-2022, 09:35 AM
Easy fix
Thanks! Called left message and also sent an email. How does it attach? It looks like it is spot welded to the lever shaft.
Ken
