Thanks George. I am going with 10W40. I was just wondering if 15W40 would be acceptable since it is so much more widely available than 10W40 or 15W50. But, yah, I can find some 10W40 for a decent price and will just go with that.
I've used the f&f stuff in several cub rears without issue. I've also used 5w30 diesel engine oil in them. I had a case 621 we were dumping gallons of hi tran in every week, finally got a case mobile guy to come over and fix it. When he was done he was filling it up with 15/40. He said that's all they ever use at the dealership.
JD x475 |
When I get around to it this spring, I will be going with 10W40 or 15W40. Probably Rotella 15W40 full Synthetic.
Thanks to everyone who lent opinions and advice. I will try very hard to remember to come back and report how things go once I get the trans welded up and refilled. |
![]() Yours is an oddball...the F&F stuff is good for the garden tractors where Hy-Tran is the spec oil.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
| Thread Tools | |
| Display Modes | |
