Old 01-04-2011, 12:24 AM
ad356 ad356 is offline
Default throttle shaft question
i got the busted screw out of the throttle shaft. when i put the carburator back together, what is the best way to make sure those screws dont losen themselves and end up inside my engine. i was thinking of using loctite. will that work?
Old 01-04-2011, 12:36 AM
TEET's Avatar
TEET TEET is offline
I use loctite on mine now. I sucked 2 of them into the engine on my 1211 this past summer..thankfully they are pretty soft, and didn't damage anything, but I learned my lesson
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 01-04-2011, 05:45 PM
I would use new (steel) screws, lockwashers, and blue loctite. Never reuse the brass screws...they will twist off when you try to tighten them.
Old 01-04-2011, 11:57 PM
got the blue loctite, steel screws and lockwashers. im starting to put the carburator back together now. this engine should be running soon and im thinking about buying a qa42 that is available locally.
Old 06-03-2011, 10:13 PM
a_tittman a_tittman is offline
Lock washers are not needed. They are just another spring in the system.
Old 06-04-2011, 12:12 AM
ajgross ajgross is offline
Inactive Member
Dude, you really need a different username. This is a family oriented site.
AJ
Old 06-04-2011, 12:49 AM
AJ
He's been checked out by the admin team and he's from the old site. He had the same user name there as well.
Thank you for your concern as this is a family site and we do proud our selfs on that.
Duke
Old 06-15-2011, 08:30 PM
Sorry AJ. I have been using this user name for a long time with no problems. Sorry if I offended you.
