Old 06-04-2024, 11:58 PM
Dajeepman Dajeepman is offline
Default PTO Hydraulic pump
I'm thinking on adding a Hydraulic pump to my 108 later this year, I debating on making a setup like this, pictures attached to pull a scraper. I see this JD have a PTO pump that he made a bracket for. I was thinking on doing the same or use a Power Steering pump. I don't ever plan on getting a 3 point since. What do yall think?
Old 06-05-2024, 06:39 AM
Yes, that is how a lot of owners add a pump. Here is how I added a pump for my FEL.
Here is the pump I used.
https://northernhydraulics.net/produ...ncentric-10566
I have seen some guys use an old power steering pump also but the mounting is different.
Old 06-12-2024, 11:49 AM
Attachment 115154
Do you have blue prints on how the front mount is made?
Old 06-13-2024, 06:14 AM
I'm sorry, I do not. It was something I made up on my own however I did purchase the pump mount from another member that is not active anymore.
Old 06-16-2024, 07:52 PM
IHinIN IHinIN is offline
https://www.onlycubcadets.net/forum/...ead.php?t=4887
I used a GM power steering pump and a JD valve to add hydraulics to my 100.
Old 06-18-2024, 03:10 PM
I used a GM power steering pump and a jD valve to add hydraulics to my 100.
what mound did you use? or was it a home made mount?
Old 06-18-2024, 06:15 PM
Farmall450's Avatar
That's a clean 100.
Old 06-18-2024, 10:16 PM
It’s a homemade mount. I had to add a jack shaft and an additional belt to drive the pump the correct direction.
