Old 09-19-2024, 09:41 AM
rsshallop rsshallop is offline
Great to see your 125 making chores easier Ken. That's why I love my 108, it always comes in handy working around the yard. With all that land you have down there, you must never stop working.
Cub Cadet 108 / no mowing deck
42" snow blade
Old 10-15-2024, 12:43 AM
RCLivingston RCLivingston is offline
Default re: steering problem on my 102
I Solved the steering issue a few weeks back. And today, I went over my 102, cleaned the soot off the spark plug, checked head bolts and tightened a couple of them. ALso noticed a rear pivot bolt on the starter generator had snapped. I was able to use a screw extractor to remove the broken off bolt and replaced it. Thoroughly enjoyed the job too. So simple are these machines! I also cleaned the outside of the engine and carb, aired up the tires in front (3 bar type) and checked the rears (turfs) added 30 weight to the rear end, and then had some fun mulching leaves and hauling a bunch of old rail road ties to a spot for the disposal guys to more easily load them. I adore this machine!
Old 11-18-2024, 11:30 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Default It's fall
Pretty good crop of leaves this year
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 11-18-2024, 04:35 PM
Radioguy41's Avatar
Radioguy41 Radioguy41 is offline
Yeah, but my GT2544 with the 3 blade deck mulched em to bits.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
1993 Craftsman LT4000
Old 11-18-2024, 04:38 PM
IHCubCadet147's Avatar
I started getting my 882 ready for winter. I took the mower deck off and put the plow on. I still have to put the chains on, but I’ll wait a while yet to do that. It’s not looking like we will be getting snow anytime soon.
Last winter I got a flat tire while I was plowing, so I put a different wheel and tire on until I could get a tube for it. I kind of forgot about it until a couple weeks ago. I got the tube in and put it back on.
I have been asked a few times how much the wheel weights on this weigh, but I didn’t know. Since I had to take the one off to change the wheel, I weighed it. 105 lbs. each, so 210 total. Big difference from the factory IH ones that weigh 26 lbs each. These are not fun to put on and take off.
Old 11-18-2024, 07:01 PM
jbrewer's Avatar
" I wish you were closer.......... "
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 12-19-2024, 10:25 AM
Gregg Ridlon Gregg Ridlon is offline
Default Gave her a pat on the way by...
As I grabbed the longer snow brush to clean off the car.
Noise ordinance says no to running her that early.
She will get woke up after work....
-Gregg
The 125: Works the snow & grass
The "6:15" (Frankenstein 125/105/?): Misc. projects testbed
Old 01-24-2025, 09:10 PM
MitchJ MitchJ is offline
Default Restarting my restoration take 5
This is probably about the fifth time I’ve restarted restoring my 782, got the dash pulled off tonight and the transmission is out. Now I can really get in there and clean this frame off for paint prep.
Old 02-07-2025, 05:25 PM
ks114 ks114 is offline
Default My 782
My 782 got a M18 upgrade. It still had the series 1
Old 02-24-2025, 12:57 PM
I dug my 149 restoration project out of the corner and plan to start working on it again. It has been a shelf for the past 5 years. Hopefully I can actually finish it this time. I bought this tractor and started restoring it in December 2017. I think the last time I worked on it was in 2019 or 2020. It’s been way too long. First thing, I need to get it running again. It’s probably going to need the carburetor cleaned and a new battery. I had this motor rebuilt, and it still needs to be broken in. I only had it running once for a few minutes. It needs to be cleaned up too. Even though it was inside and covered, it’s still dusty and covered with spiderwebs. All of the yellow parts are done, I have a few white parts that still need to be painted, and I think I’m going to redo the hood and dash. If I actually work on it, it shouldn’t take too long to get it done.
