Old 06-05-2025, 07:03 AM
I-H73's Avatar
I-H73 I-H73 is offline
Default K301 Found this in Oil
Hello Everyone I hope you all are doing well.
Yesterday while changing oil in the K301 I found this laying on top the oil drain pan.
I was hoping one of you Kohler gurus would recognize it.
The engine is running fine & I just mowed 5 acres with it after the oil change.
The old oil was 10w30 & it was black, it now has straight Heavy Duty 30 weight in it.
I put my finger in one of the pics to reference the size of what looks like a piece of cast gear tooth.
Thanks for your input.
Old 06-05-2025, 07:16 AM
Gazing into my Chrystal ball. I see a dentist in your future to replace the missing tooth with a full set of teeth on that gear.
I also suggest you purchase a lottery ticket because your luck of averting
a disaster was great.
I also see internal engine surgery in the near future.
Old 06-05-2025, 07:30 AM
I-H73's Avatar
Talking
Well IF I win the Lottery I will definitely purchase a new engine for this this ole 73.
In the meantime it has work to do & will hopefully get through this season.
IDK if that's a tooth off a cam gear or balance gear or even when it came off. I suppose I should stick a telescoping magnet in the oil drain pan to see if any more teeth are in there.
Old 06-05-2025, 09:02 AM
Ambush Ambush is offline
You’ve been lucky up till now, but myself, I’d quit running the engine and pull it apart before some of the internals try to become externals. Right now it may be a simple matter of removing the balance gears.
Could it be a tooth from the governor gear?
Measured exactly how long it is.
Edit: It looks like only part of the tooth lengthwise? Definitely get a magnet in there. Better yet, get the pan off.
Old 06-05-2025, 09:03 AM
As small as it is, I'd guess gov gear.
No balance gears in a small kohler.
You can try snaking a borescope in the drain plug opening,
if more break off, you will have a big window in the block to look into.
Old 06-05-2025, 09:23 AM
Fix it NOW!
Before it's too late.
Old 06-06-2025, 04:53 AM
I-H73's Avatar
Yea good idea.
Old 06-06-2025, 04:58 AM
I-H73's Avatar
I thought the 12hp K301 had 2 balance gears in it.
This appears to be a very small piece of a tooth off a tiny gear.
I will look in the oil drain pan & see what I can find in there with a magnet the oil is black.
Old 06-06-2025, 08:33 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Fix it NOW!
"X2" !!!!
Oz
Old 06-07-2025, 02:22 AM
I-H73's Avatar
Here's a pic of a governor gear which is plastic.
And a pic of a balance gear then a Camshaft gear.
To me it looks like a tooth off a cam gear.
