![]() Quote:
The mower deck is the most abused and worn part of the mower, so if you put some good effort into making sure it works and don't let the blades get unbalanced it will serve you much longer. As long as you regularly grease them the bearings should last for ages. My grandpa had one that I used up into the early 2000's and those bearings where never replaced. Just a couple pumps of grease every couple times you take it out to use it.
1450- 44A deck,QA-36 snowthrower, 42in front blade No.2 Tiller 70- 38in deck, 42 inch deck |
Welcome John TV. When I first saw your post about the "Order of Operations", I thought about my Algebra I class and the "Order of Operations". It made me laugh because the teacher would tell us, "Please Excuse My Dear Aunt Sally", which was an pneumonic device for remembering to do "Parentheses-Exponents-Multiplication-Division-Addition-Subtraction". We were tough guys, so we made learning tough to her dismay and changed it to "Please Execute My Dog And Sister"
![]() Congratulations, you purchased a very solid cub cadet that you will find more utility with than just mowing around the cabin. It will haul wood, help pull logs, garden, remove snow, move mulch, gravel, etc. I have owned several 149's and one thing I noticed is what IHinIN mentioned was the PTO clutch. If your 149 is an older model 149, then it will not have the safety brake on the front PTO clutch that was put on in 1974. If it predates this modification, then inspect and likely replace the wear button (cost about $15 DIY). The brake had a large round pad on it as a safety modification. Others have given you really good, sound advice already, so I would advise you to look into what they have stated, but I would also add that if you are taking your cub 149 to any shop for work, then I would have them remove the balance gears in the engine. They are a ticking time bomb. The side effect is that your cub will shake or shimmy just a little bit more than normal, but nothing bad at all. A well serviced machine will see you through another 50 years of service! Cub Cadet 123
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
Thank you all for the excellent advice. Every post had good suggestions and I will give attention to all.
John in Mn |
Really good advice to get the old girl running well.When you are working on your tractor in your home shop,notice what tools you use ,their isn't a whole box of special tools you will need to take with.I would build a supply of spare parts,that you will feel comfortable replacing if needed. My tractor,when I first got it,the driver pin and hub needed work.I replaced the hub and pins.I ordered extra pins from Charlie.He stocks some,even a bit oversized.My key was damaged, so new switch and TWO KEYS,Since these old girls vibrate,alot I periodically check fasteners.
I would also study and learn about the importance of keeping head bolts torque properly. And fresh clean non ethanol gas has made my life easier.Good luck,have fun! |
Thread Tools | |
Display Modes | |
