I think you should try one more time. See if you can find a torque spec and use a torque wrench. As you have seen the gear on the spindle and pulley will not hold without getting the flange nut tight.
Cannon |
I greased them like crazy because I have already thought that might be the problem. I am using genuine parts. It isn't always the same one.
Then it's one of 2 things either they are not torqued to spec and loosen allowing the spline to strip or something comes in contact with the blade like a rock causing the blade to stop abruptly and causing the damage
I realize this is an older thread but I had a similar issue with my i1046 and wanted to post how I fixed it.
My i1046 ruined the pulley on the left side spindle. I purchased and installed a new spindle. It took all of 10 minutes to cut the shaft on the new one in half just below the upper nut. At that point I knew something else was causing the problem. What I found is the two idler pulleys pivot on the same shaft and that pivot was rusted still. I pulled it all off, used a Dremel to remove the rust, put it back together and oiled the pivot. It has worked perfectly since then. I did research buying new parts and one of the three involved was no longer available. At that point, I made the decision to clean up the original parts. Hope this helps! |
| Thread Tools | |
| Display Modes | |
