I have an 1863 and am looking to get a plow for it. I know I need a wide frame variant but am confused on if there is further variants i have to look out for. From what i have seen/read there is internal vs. external pins on the subframe mounts but both should work. Is there a difference in front axle heights between the cyclops and older wideframe models such that the plow would be at a wrong angle? Attached is a picture of the plow I am considering buying.
You will need a 316 Blade Mounting (190-316-100) subframe. That frame you have will work for the 880,001 and below, but you need a different lift bracket, lift rod, and you will have to grind the mounting tabs to clear the axle adjusting bolts.
My bad fixed, Lift rod is a different length and thickness, bracket that is on it will not let the lift rod clear the side panel.
These are the parts you will need... Lift bracket 719-3093, sub frame 603-0046, lift rod 703-0631, plow bracket 747-3165.
| Thread Tools | |
| Display Modes | |
