Old 09-04-2025, 02:38 AM
Janomat 3000 Janomat 3000 is offline
Default part numbers Delco starter generator and voltage regulator needed!
Hello,
as my 1961 Cub Cadet Original is located at my holiday home far away i still wasn't able to fix my problem of spark only during starter cranking by battery.
My holidays are always short, so next time i'm planning to install a new starter generator and a new voltage regulator to fix the problem quick. Can anyone of you help me out with part numbers for my tractor so i can get the correct ones?
Thanks again for your help!
Jan
Old 09-10-2025, 02:17 AM
Good morning,
as i don't get any data concerning the original voltage regulator i am thinking of buying a newer type vr (the ones with cooling fins). On my knowledge i have the Kohler K161 engine and a 4 terminal vr, do you think i can put in a three terminal type that is sold for the K161? I have the Delco starter generator, not sure if later engines have different wattage on the generator.
Thanks and kind regards!
Jan
Old 09-16-2025, 09:38 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Starter/Generator IH-330820z
Regulator IH-121577-c2
These are the part numbers listed for the original however you'll likely need to cross reference these numbers for suitable AFTERMARKET replacement. I like going to DB electrical for the SG however I offer no advice on regulators because I had no success with the aftermarkets. For this, I prefer to find NOS which isn't easy.
Plow blade
#2 Cart
QA36 snowthower
Old 09-25-2025, 03:26 PM
Thanks Billy,
i will watch out for an original part if i can find one.
Jan
