Old 11-14-2025, 10:48 AM
gdheck's Avatar
gdheck gdheck is offline
ol'George
I did replace the ignition switch and it was a genuine Cub Cadet switch. That's a good point, both about a possible incorrect switch and about the ignition system not being grounded when it needs to be. Honestly, there was enough oil/dirt/grass mixture caked on everything that it could very likely have be a ground issue. I'll see if it's fixed a little later today.
johnwd98
I agree, I want to know I have the real problem fixed first. I'm one of those people, probably a case of ocd, that just can't stand to let something like this go. I let it go part of the summer, so my dad could use it to mow with and now it needs fixed.
I do have a small ball valve in the fuel line of my older tractors, to prevent a leaky needle and seat from filling the crankcase with fuel. I think it's a good idea, especially when most of mine sit for several weeks or even a year in between uses.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 11-15-2025, 08:36 AM
johnwd98 johnwd98 is offline
johnwd98
I just thought of something else, If the only way to shut down the engine is to install a cut off switch on the solenoid, then what do you if you want get off your Cub and walk away for 10 minutes or more? Do you shut off the fuel and wait for it to empty the float bowl then shut the key off, meaning a longer cranking period next time, or do you just shut off the key and wait, either way you would be waiting. Does your Cub have the "safety" kill button on the seat? There could be more complications would arise with fuel solenoid cut-off switch if not fixed correctly first. I believe the cut-off switch to be not be a bad idea but, only if your done for the day.
Old 11-15-2025, 01:19 PM
John when properly wired the engine is shut off by grounding the mags. The white wire is the kill wire. Your ignition switch should ground the white wire when you turn it off. The fuel solenoid requires power in order to open and allow fuel flow. The white wire on the engine goes to the yellow wire on the ignition switch so if you ground the yellow wire it should shut off.
