Old 12-11-2025, 01:51 PM
CubbaCudet CubbaCudet is offline
Default Buying a new Cub cadet. So many options
My 2010 Cub Cadet SLTX-1050 has officially kicked the bucket.
Model # 13WQ92AP010
Kohler engine SV730
I have replaced nearly 80% of the original parts to keep it going this long. Got many good years out of it but it's time for something new.
  1. I need something robust that can cut a yard that is up to 3 acres.
  2. Is robust enough for plowing snow in winter (SLTX-1050 was a champ!)
  3. Don't need bells and whistles, but comfort is important in old age.
  4. Can tow heavy loads with an attached 2-wheeled cart.
  5. The wider the cutting deck the better. SLTX-1050 was 50".
  6. A transmission that can handle moderate hills without overheating.
Reviewing this site for days, I've concluded the XT2 GX54D model would be a good fit but I think it's discontinued. Based on expert opinions in here, are their models that replaced the XT2 GX54D which have similar/same specifications? Suggested other models?
A friend told me dont get the SLX 50 if I'll be pulling a 2-wheeled cart behind it filled with wood or pushing snow because it'll blow the transmission, and to find one that uses the K58 or K62 transmission. Would the XT2 GX50 with the K58 transmission be sufficient?
Thank you
You only need two things in life: duct tape and WD-40.
If it's loose and supposed to be stuck, use duct tape.
If it's stuck and needs to be loose, use WD-40.
Old 12-11-2025, 04:47 PM
Have you considered something more heavy duty like Kubota or john deere?
Today,
MTD makes average homeowner equipment, not compact utility tractors, which
sounds like what you are looking for.
Old 12-12-2025, 07:19 AM
Sergeant's Avatar
Sergeant Sergeant is offline
Model # 13WQ92AP010
Kohler engine SV730
Thank you
It's the XT2 GX50 that has been discontinued Not the XT2 GX54D
Old 12-12-2025, 10:17 AM
Road_Clam Road_Clam is offline
Ive had my 54D for about a year. Very much meets my needs and expectations. If your thinking about moving snow or your property has hills you definitely should go with the 54D as it has the manual differential lock which will be mandatory for moving heavy snow. Ive done several functional upgrades that makes a great LT even better.
Old 12-12-2025, 11:15 AM
Today,
Is this a test to test loyalty to Cub Cadets?
Old 12-12-2025, 11:16 AM
Upgrades? Do tell!
Old 12-12-2025, 11:18 AM
Thank you. I was hoping that was the case
I think the GX54D has the Kohler engine instead of the Kawasaki. Is that something to be worried about?
Old 12-12-2025, 12:03 PM
Sergeant's Avatar
Not really. My friend's 2017 XT2 GX 54D has over 3000 hours with a Kohler engine. The only engine issue he had was an oil drain, which Kohler updated and fixed through a recall, and the current Kohlers have the corrected oil drain.
If You want a Kawasaki version You can get it here https://www.craftsman.com/en-us/prod...ing-lawn-mower either at an Ace Hardware or a Lowes store
Old 12-12-2025, 12:18 PM
CubDieselFan's Avatar
Wow, that is a lot of hours in a short amount of time. How many acres does mow with it?
Old 12-12-2025, 04:06 PM
I meant it in all sincerity, if I need tool to do a job and a store does not have it, I go to another store to get what I need to do the job.
I have many pieces of equipment on my farm, all different colors but you can bet they are are very old like me, none of it is throw -a-way, with built in obsolescence made in the last 30-40 years.
By no means did I mean to offend, just make you aware that blind allegiance sometimes causes remorse when a choice was made and it is not able to accomplish what we wanted or needed.
I don't purchase a hand shovel when the job calls for a Backhoe.
And I understand a Backhoe is a bit of an overkill to dig flower bed.
I hope you find a capable piece of equipment at a fair price that will make glad you chose it and it lasts a lifetime.
Tags
new cub, pto, xt2
