Old 04-27-2026, 01:22 PM
Farmall450's Avatar
Originally Posted by green407 View Post
Why a 6 ply and not 4 ply? your cub can't weight that much.
It's only a few more bucks, but I'm sure I'll regret it when I go to mount them.
Old 04-27-2026, 03:25 PM
green407's Avatar
green407 green407 is offline
I get that it's only a few buck, but the 6 ply tire is rated for 1800lbs, the 4 play is closer to 1200lbs. no way a cub warrants such heavy tire.
Don't get me wrong, they look good, and having the extra traction in the soft ground is amazing.
128 X 2, 129, 149, 1250, 1450 x 2
Old 04-27-2026, 10:17 PM
I agree 1000 %
Back in the day, they said steel wheels with lugs would out pull those silly soft tires anytime, but they lived to see that was not so.
As a kid, I remember seeing signs on rural roads saying:
"Tractors with lugs keep off"
Old 04-30-2026, 04:51 PM
Cubcadet782desiel Cubcadet782desiel is offline
I was looking at deestone rears for my 782d I would like to put duals on for rolling lawn and pulling stuff where do I find cheap rims to put on it and what is the best spacer I was looking at the ones that are a steel ring that goes in between the tires and you would use carriage bolts to hold them together.or would a set from extreme motor works be better the only thing is they aren't cheap.
Old 05-01-2026, 09:09 AM
Billy-O's Avatar
Billy-O Billy-O is offline
https://www.xtrememotorworks.com/col...nd-accessories
Plow blade
#2 Cart
QA36 snowthower
Old 05-15-2026, 08:54 PM
Screenshot 2025-02-26 6.48.38 AM.jpg these are the tires that I have they are also deestone lugs on my 782d
Old 05-18-2026, 05:35 PM
Farmall450's Avatar
Time to flip these onto the 1650.
Old 05-18-2026, 05:46 PM
Ambush Ambush is offline
And ags look good front and back!
Old 05-20-2026, 11:43 PM
Farmall450's Avatar
Also took this opportunity to get the sleeve hitch casting mounted.
This machine had the frame bosses, so I cut a piece of 5/8 hot rolled at 11.5" and drilled 2x holes for the hitch pin clips.
These smaller Deestones certainly rake the tractor backwards more than it was before.
Old 06-05-2026, 06:10 AM
PBIjim's Avatar
PBIjim PBIjim is offline
My experience changing from 4 ply to 6 ply on a pick up truck was that the 6 ply tires were more stiff. When I towed a trailer with the 6 ply tires, I had a lot less trailer sway. Cornering was more solid.
In the case of a garden tractor, I would suspect that a 6 ply will bite in better and a softer tire will do less damage to soft surfaces.
The heaviest I have used on a pickup were 10 ply mudders. Even if I aired down to 12psi, those stayed stiff. The contact patch didn't grow. The off road guys who do a lot of "rock hopping" seem to like those because they are hard to tear up.
I think that R2 tread style tires in 10 ply are available in sizes that fit on the wide rear Cub Cadet rims. I don't know that super stiff industrial tires like that would provide an advantage here. I mostly see those tires on skid steer equipment.
A pair of 100's, both look fairly well stock, one with a creeper, and a snow plow that I will never use in south Florida
