Old 02-05-2011, 08:08 PM
mc25a mc25a is offline
Default Snowblade questions
I got most of a 42" snow blade today but the linkages don't look like those I've seen elsewhere. Here are some pictures:
The bar is a larger diameter than the hole in the lift lever:
I was told the piece on the left goes around the lift lever to accomodate the larger bar:
It also has a different mount on the blade itself:
So I guess the piece on the right bolts in there, but what's the piece in the middle for? As you can see in this view there are two set screws:
Thanks for any insight you can provide,
Old 02-05-2011, 08:16 PM
Left bracket is for a manual lift 82 series tractor, right one is for a late hydraulic lift cyclops tractor. What are you trying to mount this on?
Old 02-05-2011, 08:22 PM
Model 86. It looks like the left bracket will fit my lift lever, but then the length may be wrong huh?
Old 02-05-2011, 08:53 PM
For an 86, you don't need either bracket...there's a hole in the cast piece of the lift handle for the lift rod to go in. You will need to make a new lift rod.
Old 02-05-2011, 09:35 PM
OK, it turns out I have the "new style" snow blade. I could tell because my springs mount differently. I think I can make it work with what I have, but I'll post my progress once I get the undercarriage,
Thanks
