Old 02-14-2011, 12:09 PM
APPALACHIAN EDGE's Avatar
APPALACHIAN EDGE APPALACHIAN EDGE is offline
Default kohler help asap please
A few wks ago i rebuilt a 10hp kohler motor its ran pretty good just needed carb adjusted ! guy was coming to pick it up so i pushed it outa the garage & was going to start & fine tune carb ! WOULDNT START!!! So that really put a knot in my plow line cuz i had to call him back & tell him it wasn't ready after all ! I checked the usual & nothing obvious ! As not to drag this out this is what Ive done over the last three days !! CHANGED : points 3 times, coil twice, condenser 3 times, adjusted valves 3 times to specs 1 time by site, 3 different carbs & 3 different plugs & it does the same thing every time valves in 00.9 exh 00.18 plug gap 30 points 20 ! Anyway symptoms are as follows
crank,crank,crank & nothin, pull plug no gas in chamber so i figure vacuum leak right cuz gas pours out carb when i choke it with my hand over it ! it will fire one time maybe a pop pop but no more than 3 & that's all your gonna get till i go through the whole song & dance again & then you might get it to do it again ! i can feel good compression leaking off real slowly when turning it by hand but that's normal right? i can hear carb sucking air on intake stroke also so anyway im stumped & need new set of eyes to go over this & tell me what I'm missing they all seem to run together after a while !
I won't be wronged, I won't be insulted & I won't be made a fool of !
I don't do these things to others & I require the same from them !!
Old 02-14-2011, 12:37 PM
nashcub's Avatar
nashcub nashcub is offline
AppEdge,
I went through EXACTLY the same thing this past weekend on a 1450! Engine ran before I replaced all of the ignition components and rebuilt the carb.
Once all back together, it would not even act like it wanted to fire. Found some trash/water in the fuel bowl. Removed carb and gas tank for thorough cleaning. Did notice that the ring gasket on fuel bowl may not have been seated properly. Put it all back together again and still nothing more than an occasional backfire (more like a poof!) through the carb.
Checked and double checked everything. As a last resort, I finally went back to the timing using the 'static' procedure again and put the flywheel "S" just below center of the viewing window. Cranked it over and it fired right up and ran great!
So, if you have fuel and fire, I would suggest tweeking the timing setting up and down to see if that gets you anywhere. I've seen some posts where guys run anywhere between 13 and 22 degrees, so I guess dead on 20 is not necessarily perfect.
Not sure if this will help, but it did work for me! Please keep us posted on your results!
S
Old 02-14-2011, 12:54 PM
Originally Posted by nashcub View Post
AppEdge,
S
Thanx nashcub i never would thought to set points that close but im at a stand still as it is right now so ill play with it a lil more & let you know
Old 02-14-2011, 12:57 PM
nashcub's Avatar
Are you using the 'static' timing method with a multimeter?
Old 02-14-2011, 01:20 PM
uh! no I'm not qualified for that particular piece of technology lol! No i dont have one ! be a good time to own one though!
Old 02-14-2011, 02:00 PM
Best $10 you'll spend. You could use a timing light if you have one of those. Both methods are better then setting points at .020.
http://www.onlycubcadets.net/forum/s...ead.php?t=4405
Old 02-14-2011, 03:44 PM
Just kidding,
Im just trying to keep a light heart about things ! I seem to get frustrated alot easier these days lol! I had both a light & meter at one time all i remember is i loaned them to someone & they were both red & it had to be at least ten yrs ago cuz that was when i was working outa my old shop lol!
So harbor freight has them for three bucks seem like when i looked to replace mine (10yrs ago) they were like 30 bucks wasnt hf though ! ill look into that thanx
Old 02-14-2011, 05:28 PM
Default Problem solved
Re: kohler help asap please
Originally Posted by ford_lgt_165
did you do re-wire this engine ?
Setting the gap @ .020 is a fail safe you still need a timing light to make sure it bang on.
Bad ammeter will cause grief.... Thats why i remove them and re-wire in a voltmeter. Why kohler wired these engines to die when the ammeter blows is beyond me !
ok this needs to be posted somewhere
THANKYOUTHANKYOU THANKYOU FORD_LGT_165 In all my dealing i have never seen such or for that matter heard of such!! Just goes to show there's always somebody out there that a person can learn from ! Sorry I'm typing slower than usual i seem to have sprung a leak in one of my fingers after the fight with the amp meter but its now over the hill along with all the bad words & motors purring like a half sick cat with distemper ! UNBELIEVABLE!!! I feel sorry for you ford_lgt_165 if you went through what i have the last lil bit ! but if you hadn't then you couldn't have solved my problem ! maybe someday i can pay it forward to someone? & ill have to give you an I O U till maybe we meet sometime ! thank you again ! I have put a charger on the battery & decided to quit for the day & start fresh tomorrow on fine tuning thanx all you guys its good to know friends have got your back !!!
Old 02-14-2011, 06:04 PM
So the ammeter was the culprit? Would have never considered that. More good info to write down.
Old 02-14-2011, 10:00 PM
YEAH I Know can you believe that ? that thing wouldn't do nothin , It would fire just every now & then when you first try it i cranked & cranked hand choked carb till it was pouring out , tried timing in every position imaginable , wore carb out cleaning it, pulled the head at least half a dozen times , cleaned & prepped valves, the thing is it was getting what i thought was good spark to it & it was when i looked but i guess just ever so often ! Its gonna take me a while to get over this one ! i never in my life even heard of such ! i wonder why thats not in any of the service manuals?
