Old 02-23-2011, 06:35 PM
I've had several new batteries that were DOA...
Old 02-23-2011, 09:39 PM
cdmintmi cdmintmi is offline
OK... I checked and re-cleaned every connection I could find today and then put it all back together and redid the stator and regulator test. Again everything checked out and this time the battery trickled down to 12.5DCV and seemed to hold at least for a hour or so. Ill check it again in the morning but I'm thinking I might have had a bad connection in there somewhere. If its not right in the morning Ill take the battery back to NAPA and try that. Thanks for the help, this forum is really helpful. There are tons and tons of info on here that isn't only for cubs but could help a lot of different people, but the cubs on here are pretty cool. Cant believe I only recently found this site, I hope it doesn't cost me too much because now I really want a true cub instead of this mid 90's knock-off I have. One day.....one day
Old 02-24-2011, 08:08 AM
Check all your connections between the V/R and the Battery. See image..
Old 02-24-2011, 10:50 AM
Battery was still holding at 12.4 volts this morning and she fired right up. First time since I started this project that I was able to just sit on her and go with out jumping it off with the truck!!!!! Thank goodness, I was getting tired of jumper cables. I think I must have missed a connection the first time going through. Thanks for all the help guys, you and this site rock. In my experience if there is problem its normally not the new parts, its the installer.
I found a headlight assembly on flebay for 40 bucks so I bought it (cub wants 80 plus s/h). The tractor just looked bad without that big opening where the lens should be. Now I have to figure out how to fix the wiring that my dad cut (see picture above). Anyone know a part number for the connector that the light bulb hooks to or even if you can buy just that? Its not listed in the parts break down I have. Or should I just cut the other one off too and take to a parts store and then patch both of them?
