Old 03-19-2011, 12:51 PM
Unless someone changed the ignition switch, the lights are turned on and off by the ignition switch. The switch has 4 positions from left to right: Off, run+lights, run, and start.
Old 03-19-2011, 01:01 PM
cubfan's Avatar
cubfan cubfan is offline
That is probably what has happened,it is only a three position switch.I had to reconfigure the wiring harness at the switch and I was thinking the maker of the harness had made a mistake.Oh well it should be no big deal to install a seperate switch plus I kinda like how the lower dash tower looks with an additional switch there because it has absolutely nothing down there except for the choke cable knob.Thanks for the info Matt!!!!
Old 03-19-2011, 09:30 PM
Mountain Heritage's Avatar
Is that the stock size of front tires or you go up a size? Really do look sweet. Anyone else have any issues with the front ags ripping up grass while mowing?
Mike
Ontario, Canada
Now everyone wants a Cub!
Beware of the Wife
Old 03-20-2011, 08:49 AM
cubfan's Avatar
The orginals were 18x8.50x8's.Thats the size I was searching for when I got these,but these were on sell at a really good price so thats why I went one size wider!!!!
Old 03-20-2011, 03:27 PM
Iowa Farmboy Iowa Farmboy is offline
I have the exact same front tires on my 2072. I have no problem tearing up the grass, but I do not try to corner at high speeds.
Josh
1989 SGT 2072 (restored)
60"Haban Deck, 54 "Haban Blade, 48" Cub Cadet Tiller, 12" Brinly Cat O plow, 48" Cat O landscape rake
Cub 128 with creeper and rear PTO with reverser(next project)
IH built 682 and 782 that will combine to make one
