Hi all!
I'm new to OCC, actually I'm new to forums in general so please excuse any,,,,well you know. I'm in the process of restoring a 1650 but am having trouble getting the steering wheel off. Common sense says, remove the nut and pull it off. Of course nothing is ever really that simple on a 40+ year old CC. I have pullers of all shapes and sizes but nothing seems to fit without damaging the wheel. I would really appreciate any advise. Thanks, Tommy |
Only use that if you want to replace the bearings in the column. Here's what I use:
100_3557 (Custom).jpg |
I think one of the mods suggested this method using an air hammer and a long 3/8 bolt with the head cut off and nuts to help hold it into the hammer spring. I Loosened the steering wheel bolt but did not remove it completely. I loosened up to the point that it was flush with the top of the steering shaft. Inserted the bolt and hammer. While pulling upwards with one hand and then using the hammer to apply vibrations. I would rotate the wheel about 1/3 of the way then use the hammer again. The third try and the wheel popped loose. Unlike using a big hammer with repeated blows to the shaft that can damage bearings and bearing cups this won't do that.
I've tried all of the above and the only way to get a real tuff one off without damaging the bearings is to go with Matt's idea and use a puller. Mine is a Snap-On and they run about 120 bucks but Harbor Freight has them for about 40 bucks.
Chug a lug a luggin’ 5 miles an hour On my International Harvester |
I agree.. use matts idea. you can pick a cheap bolt puller up almost anywhere. a couple blocks of scrap wood and there you have it. gets the wheel off with no damage.
Hey Tommy, Welcome aboard. Those ideas might work, or you could use the right tool for the job! Wanna see one removed in under 5 mins.?http://www.youtube.com/watch?v=YQJlvbw8NXQ
I have removed steering wheels from several different garden tractors. Oak's method is the one I have always used. Just be sure to "soak" the nut for several days before trying to remove it with PC Blaster. Apply marine grade "nev r sez" when you reinstall the steering wheel.
Papaw 1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift. ![]() |
![]() Quote:
Fool me once shame on you,fool me twice...shame on me! |
I only have 82 series tractors and an O...haven't touched the O yet. All of the steering shafts are hollow. What you can't see in the picture is that I'm using an additional round piece between the steering shaft and puller to prevent mushrooming the shaft.
Thread Tools | |
Display Modes | |
