Old 04-08-2011, 10:17 PM
SwampRatt-1977's Avatar
Default ~ help plzzz! ~
what does this look like to you guys.
Old 04-08-2011, 10:18 PM
i hope its not holding the tractor togather lol
Old 04-08-2011, 10:29 PM
Looks like you found The Mother Load Of Cubs!!!
And yes that is holding it together...
Up to 534 and counting...
Old 04-08-2011, 11:07 PM
Southtowns27's Avatar
Too bad Minnesota is so far away....
Old 04-08-2011, 11:52 PM
The bolt holes in Cub Cadet Original frames had a tendancy to crack where they bolt to the gear reduction housing. They aren't very hard to repair, depending on the crack, you can weld it back up or make a doubler plate and weld it in there. The sucky part (as you already know) is that PO,s would drill holes in the cast iron reduction housing to "repair" the frame. Cast iron doesnt "fix" as easy as steel, You can put some masking tape over the hole on the outside and put some JB weld in the hole from the inside... The masking tape will give the filler a look that is similar to texture of the cast iron.
Old 04-09-2011, 01:19 AM
Heck, if you don't like that cub, then I'm sure that there is another one there that you would like!!! Wow, I wish that was in my backyard!!!
Old 04-09-2011, 07:25 AM
mmzullo mmzullo is offline
Sure i'll buy it. O's are hard to come by. By the way easy fix. What's on the lift arm?
Old 04-09-2011, 10:01 AM
Tractor2nv's Avatar
Tractor2nv Tractor2nv is offline
Hmmmm? Whats on the rear and what kind of breather is that too? Of all the Cubs I have had the Original is the most model I have had...here is three more I have found in a shed. 1961 early with collar spindles,62 and 63 with fenders but they all go together for $1,200!
Fool me once shame on you,fool me twice...shame on me!
Old 04-09-2011, 06:39 PM
Those are some sharp O's , Kevin!
Old 04-09-2011, 08:33 PM
Delivered?
