Old 04-09-2011, 06:27 PM
Mooner's Avatar
Mooner Mooner is offline
Kelly, that's a great idea to install studs on the wheels. I can see how that would make make it so much easier to put wheels/tires on. What length stud did you use and how tight did you make them?
Your 682 looks great with the new Ags.
Old 04-09-2011, 06:51 PM
Kelly those look so sweet!
Old 04-09-2011, 07:03 PM
Sminkey
Guest
Posts: n/a
Gotta love the new rubber, Nice ag's, Looks great!!
Old 04-09-2011, 07:29 PM
cubs-n-bxrs's Avatar
Default Lug Studs
Mooner I used 7/16-20 x 1 1/2 grade 5 bolts that I got at my local NAPA store.
I cut the hex head off with a cut off wheel and cleaned up the cut area on a belt sander and added a little chamfer. Next I coated the end to be threaded into the hub with 682 green loctite and threaded the studs in flush with the back. Let it set up for an hour and you are good to go. I could have just used longer bolts and threaded in from the backside but didn't want to see the bolt heads on the inside of the hub. Add 10 lug nuts and you are done.
Old 04-09-2011, 11:49 PM
westofb's Avatar
westofb westofb is offline
I bought a set of these for my project:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=220757088393
they come with 2" bolts that thread in from the rear, but I have disk brakes on the 149 project and paid the $6.00 up charge for studs. I would post a pic of what I got but they are in the work shop, they did come with a set of regular nuts also. I test fitted them on the tractor, plan to use the nuts on the inside of the wheel hub and tighten them up to the hub to lock the studs in place. Chrome lugs will look very nice when I get the tractor done, and will paint the nuts on the back side so they will blend in with the tractor....will be hard to see them anyway with the external brakes!
Oh yeah, almost forgot, new tires look nice on your 682!
Jeff
Brookfield, MO
________________
