Old 04-26-2011, 09:57 PM
timfitz's Avatar
timfitz timfitz is offline
Default Push Blade
Hi Guys
I bought a 1340 recently that came with a plow (pic in my album). I need to use it to push some dirt and gravel but it has a trip mechanism that keeps engaging. Does someone know how to disengage this trip thing.
Thanks for your help.
Old 04-26-2011, 10:04 PM
V@rmint's Avatar
V@rmint V@rmint is offline
Your blade was meant to push snow and to trip without putting excess strain on the tractor. If you are goung to use it for dirt, you will have to replace the springs with some type of solid link. Just be aware that this could cause the attaching parts to crack and break.
Old 04-27-2011, 03:55 PM
timfitz's Avatar
V@mint appreciate the info and your advice.
Old 04-27-2011, 09:52 PM
Rales Rales is offline
Not sure if your Blade is a normal IH blad but on mine it has a little oval peice with a handle right on the top that when you turn it and pull up you can lock the blade so it does not tip. It should be right in the center top of the blade if you have one.
Old 04-29-2011, 02:18 AM
timfitz's Avatar
Thanks Rales but mine doesn't have a handle on top. I have a pic of mine in my album, It's an older one that I believe has been modified but not sure.
