Old 04-29-2011, 09:51 PM
cub108 cub108 is offline
Default carb rebuild
Does any one have the Kohler numbers for the carb rebuild kit for the 10 horse motor with the Kohler carb. I am almost certain it is the Kohler carb by looking at the pics i found. It does not have a name on it and it has three adjusting screws.
Is there a master rebuild kit? all gaskets, float, needle seat, idle and fuel adjusting screws, throttle shaft bushing, or do i have to buy things separate.
If so, can i have the part numbers of each or please send me just a link with the info.
thank you
Old 04-29-2011, 09:57 PM
westofb's Avatar
westofb westofb is offline
Your carb should be a #26, look down the throat behind choke butterfly, should have a raise 26 cast into the top of the carb between the choke and throttle plates. It uses a KH-25-757-01 kit...here is a link to look up the part numbers from parts tree, you will se the carb rebuild kit under item number 26, ironically:
http://www.partstree.com/parts/?lc=c...&dn=0012400003
Member Mattg has his own cub site, go there and he has a very nice how to rebuild your carb!
You need to buy the three parts separately, the float is part number (item 21 on parts tree diagram) KH-25-757-03S and see the pic for part number on the throttle shaft bushing!
Jeff
Brookfield, MO
________________
Old 04-29-2011, 10:27 PM
thanks,
does the kit also come with the needle and seat and the high,low, and idle springs and needles?
thank you again
Old 04-29-2011, 10:38 PM
westofb's Avatar
Originally Posted by cub108 View Post
thanks,
thank you again
The kit comes with a new needle and seat, the bowl gasket, the bowl baffle gasket, and the gasket that goes on the nut that holds the bowl on. Your old springs and high and low needles should be re-useable after some cleaning. If you need those items, they have to be bought separately. The site sponsors have are a good place to order these parts, or go buy you local cub dealer, he most likely has them in stock, or can order them for you saving on the shipping. I ordered my parts from Chis Westfall, Cub Classics, at the top of the page....however, he has run into a snag on the float kits, I am still waiting to get mine, they are on back order!
Jeff
Brookfield, MO
________________
Old 04-29-2011, 10:47 PM
westofb's Avatar
Here is the link to Mattg's how to rebuild your carb:
http://mgonitzke.net16.net/tools/carb_rebuild.pdf
Here is what my carb looked like prior to rebuild:
Here is what it looked like afterwards:
I was bored (waiting on parts and what not) so I buffed the case of the carb and the brass parts with a stainless steel brush in my dremel tool, then I wet sanded the bowl with 400, then 100 grit wet/ dry sandpaper and buffed it out to a mirror finish (mother's mag wheel/ aluminum polish)....it looks better in person!
Jeff
Brookfield, MO
________________
Old 04-30-2011, 10:49 PM
thanks
sorry, one last question. what about the gastket inbetween the block and the carb?
that carb looks sexy.
Old 04-30-2011, 11:04 PM
westofb's Avatar
thanks
Does not include that gasket either, or the gasket that goes between the carb and air cleaner.
Thanks, it turned out pretty good, oh by the way, just got word from Chris Westfall, the carb floats are in and mine is headed my way!
Did you look at Mattg's how to? It says he thinks the butterfly screws are #3-48, that is correct, only remove the ones in throttle shaft, I removed the ones in the choke shaft as well and caused nothing but headaches, they are very easy to twist off and very hard to remove once twisted off, trust me I know, I twisted off a total of 6 during dissassembly/reassembly! Follow Matt's advice and order a set of steel screws and lock washers (don't order the brass ones, they are 4 of the 6 I twisted off!) for the throttle butterfly, will make putting it back together so much easier!
Jeff
Brookfield, MO
________________
Old 05-01-2011, 12:24 AM
thetucks thetucks is offline
I picked up the screws to replace mine at my local hardware store for 16 cents each. #3-48. Dont forget the loctite.
Old 05-01-2011, 12:33 AM
The last carb rebuild I did I didn't even take the butterflys out. Didn't have any problems and the 125 runs so sweet!
Old 05-01-2011, 12:53 AM
Iluvtruks0's Avatar
LOL HA I totally agree. I think I might try that one day. I really like how that looks
David in NC
