Old 08-06-2009, 10:08 PM
papaglide's Avatar
Thanks Diz. Same here Matt, good luck with the 782D.
Old 08-06-2009, 10:09 PM
Jim H.'s Avatar
Jim H. Jim H. is offline
Well , I mowed today, but I'm getting the feeling that the 108 needs major
attention .
Last two times I mowed, started to use oil [half a qt in an acre and a half.]
mentioned before that it was smoking mostly out the breather, now when it first starts coming out the muffler big time for almost a whole lap around the yard then backs off . then returns back to the breather on down hill right turns mostly.
also noticed sparks coming from the throwout bearing area when I got off to move a down drain pipe.
Hope I can get another couple months out of her.
Thinking of givin er the heart out of the Bolens. 18 HP V twin Van Guard.
Just wondering If PTO bearing would be OK.
Every time I find the key to success, someone changes the lock
Old 08-06-2009, 11:51 PM
RPalmer's Avatar
RPalmer RPalmer is offline
Jim H.,
You should look over your engine when you can to see just what you have going on. I had a K301 that smoked like a fog machine. It was a nightmare inside. On the other hand I have had two K241 that smoked, one really bad. The one only needed de-carbonized and a valve adjustment. Of course truing up the head did not hurt either. The other got the same treatment with a new piston, rod and rings. They are both running strong and smooth. What I'm trying to say is that it might not be all that bad inside and you won't know till you look. And based on what I have seen with my tractors I think an inspection is very worth while.
Old 08-08-2009, 02:03 PM
1811 1811 is offline
Unhappy
Well I am still trying to figure out how to mount my IH model 2 tiller to my 1811 3 pt bracket the way that the previous owner supposedly had it. I have a thread in the attachments section with pics up for suggestions and advice if anyone is interested.
Old 08-08-2009, 11:52 PM
Spent most of the day on the 149. Loaded up and went to the property where i grew up to do the mowing there. Then headed over to my friends house to help him mow. Between the 2 places it was about 7 hours of seat time :biggrin2.gif:
Getting unloaded and ready to mow.
Heading down to mow around the pond.
Finishing up.
Old 08-09-2009, 07:31 AM
RPalmer's Avatar
Diz Jr.,
That is a great mow. Some of what you cut looks to be over 3 feet high and I don't see any clumps or piles or stragglers. What is your secret?
Old 08-09-2009, 10:01 AM
RPalmer,
I just mow the open areas. The tall stuff is just around the edge where i mow. The one picture where i am headed down the hill is just my path that opens into another small field.
See if this video works, You can see where i was mowing
Old 08-09-2009, 09:04 PM
Plowed with the 582 and 782D at a plow day today...
Old 08-09-2009, 10:10 PM
Great pics and vid Diz!
Matt: Looks like you were having a great time.
Old 08-18-2009, 10:21 PM
Got some seat time in today, on the 100. Had some leaves to sweep up. No pics this time though.
