Old 08-05-2011, 02:15 PM
blue83ranger blue83ranger is offline
Default rear pto attachments?
I was just curious if anyone knew what all was available for the older cub cadets with a rear pto? I think i remember reading in the cadet connection that international didn't offer anything, it was all aftermarket stuff. My uncle said he use to have a tiller that was powered by the rear pto. Which i really wish i could've got. thanks for any info.
1983 ford ranger 302 4x4
1966 122 cub cadet
creeper, 3 point, rear pto, duals, 4 rear wheel weights
front blade
rear blade
Brinly plow
snow thrower
mower deck
Old 08-05-2011, 04:30 PM
red56turbo's Avatar
Boy,
The only rear tiller that I know of that was powered by the rear PTO was a tiller for a super GT, 982, 1872, etc. Those are hard to find and pricey.
My Dad used to have a 124 with rear PTO. Ran a grain elevator with it. He said it did a nice job. The 124 is long gone. Wish I knew where it went........
I remember seeing a Haban Sicklemo someone had fabricated to run off a rear PTO. Can't remember who owned it. CRS....
Josh
Diesel Cub Cadets...........
Old 08-05-2011, 05:15 PM
YUP....IH did NOT make any implements for the rear PTO on the IH Cubs. Further, the PTO ran backwards to most applications and needs a "reverser unit". The "cool factor" is the only asset this option offered. Other than that, they were virtually useless.
Old 08-05-2011, 07:28 PM
Well, that's disappointing, but good to know. Just out of curiosity I was told the cub tractor and the cub cadet had literally the exact same transmission (the 3 speeds) is that true?
1966 122 cub cadet
front blade
rear blade
Brinly plow
snow thrower
mower deck
Old 08-05-2011, 11:08 PM
Merk Merk is offline
My Dad owns both :
Both mowers run off tiller drive. The Haban mower would work on a PTO equip Cub.
by blue83ranger
The transmissions were the same. The Cub Cadet has a rear reduction box in front of the trans and the Cub doesn't. The gear reduction changes the direction the imput shaft rotates.
Old 08-06-2011, 09:57 AM
elbertjolley elbertjolley is offline
Is the red trator come like that or is it some type of conversion?
Old 08-06-2011, 11:02 AM
by elbertjolley
The tractor started life out as a Cub Cadet 149.
Old 08-06-2011, 12:46 PM
ajgross ajgross is offline
Inactive Member
IH actually did make a attachment for the rear pto's. Well, kind of. They made a right angle gearbox that was actually for the f-cub that will bolt right on. I know a guy who has several of them and powers a bunch of flat belt stuff. I know he has a can crusher and a corn grinder that run off of a flat belt. He also has a trailer with a ice cream maker that he runs with a v-belt. Pretty cool.
AJ
Old 08-06-2011, 01:30 PM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
I was hoping Merk would post the picture of the Haban mower. It looks like you would have to build an attachment that would be designed around the constraints of the rear PTO. The gear reduction in front of the transmission, along with the possibility of a creeper being used changes the speed on the PTO given both gear reductions are in front of the power input for the rear PTO.
Now, that being said, don't let it discourage you from building (or modifing) an attachment you want or need as there are ways to get the function of a rear PTO without the typical layout & design that we commonly think of when we talk about a rear PTO. Both of the tractors that Merk posted are excellent examples of this. The benefit of the going the route of the QL tractor shown is that (and I'm assuming now) most of the parts used are standard Cub parts, so if something breaks down the road, you wouldn't have to fabricate up a new part.
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
Old 08-06-2011, 02:25 PM
. I really want to get a rear tiller but running it off the rear pto wouldn't be a necessity. But i guess since i have one might as well, plus I would think it would be in the way of the gear box for one that runs off the front pto. I could always just buy another cub cadet for one too, which i wouldn't mind having a 100 with the round rear fenders. or maybe a 123.
1966 122 cub cadet
front blade
rear blade
Brinly plow
snow thrower
mower deck
