Old 08-10-2011, 06:14 PM
brentwd's Avatar
brentwd brentwd is offline
Default Hydraulic angle attachment for blade
I have been contemplating building the mounts to angle the blade on my 1650with dual hydro. I have built the mounts and planned on using a lift cylinder from a quietline. After looking at some photo's of other kits I realized the piston on the cylinder might be to small. I know the cylinder will have to be redone as the ports will exit to the rear and not at top or bottom. Any ideas would be welcome.
Old 08-10-2011, 06:46 PM
Try using a cylinder from a 149 or a 169. They match the original style.
Old 08-10-2011, 10:21 PM
IHinIN IHinIN is offline
I used a 1.50" bore x 7" stroke cylinder for mine.
Here's the factory setup.
Old 08-11-2011, 12:02 AM
Contact Cubcrazy aka Mike he has 3 power angle setups not that they are for sale (I did try tho!) He will be able to help you with sizes and such. Just saw Adams post he can help as well!
Adam sweet as always!
Old 08-11-2011, 12:54 AM
wig wig is offline
I built my own using original brackets for the larger cylinder and used a hydraulic cylinder off of a combine head lift. Cant remember what brand of combine, but I went to a combine salvage yard and had lots to pick from, Had original cylinder to base my measurements from and the one closest I had to just shorten the ram by cutting a little off and rebrilling for the pin on the end. The one I ended up using also had a 1" ram. It will never bend. Good luck and if I can answer any more questions just email me.
Red 782 w/dual hydraulics & Ags. Power angle snow blade, QA 36A snow thrower, rear IH blade, tiller, #2 trailer, mower, custom made winter cab and brinly plow.
