Old 08-18-2011, 09:11 PM
hydrocub hydrocub is offline
Default Mower Deck protection
OK people . Got the 44" deck blasted / stripped down and primed . Now I'm not
so sure as what I want to do for protection under the mower deck .
It's in pretty good shape and I would like to keep it there . I know this
is
. but I need to make a move on this real soon .
What would you do for your keeper .
Old 08-18-2011, 09:16 PM
I primed and painted mine, then used that spray on truck bed liner.
It seems to be holding up well.
Just my
Old 08-18-2011, 09:18 PM
superduty5.9's Avatar
superduty5.9 superduty5.9 is offline
I would put on a good coat of primer and then spray on bedliner.
Old 08-18-2011, 09:21 PM
CC1650Dave's Avatar
bed liner under the mower deck? that's the first I've heard of that one...What about the sticking grass issue? It seems you want a smooth surface, I've even read where guys are using marine teflon paint to try and reduce grass sticking.
Old 08-18-2011, 09:22 PM
There is a thread on here of someone doing this and worked out very well!
Old 08-19-2011, 09:45 AM
Diz , how long ago did you apply it ?
Old 08-19-2011, 07:32 PM
mmzullo mmzullo is offline
Use slip plate or ez slide. Both are a telfon paint. Works great in the drum and chute of a snow thrower also.
Old 08-19-2011, 07:44 PM
AMCJavelin74 AMCJavelin74 is offline
I've heard of guys using 'graphite paint' (I think it's something special from ag stores. Ask someone at your local farmers co-op.) on snowthrowers. This stuff might work for mower decks.
With rocks, sand, and even grass whirling around down there, it's a rough environment for any coating.
CC 128 (Sept. 74)... and other vintage non-CC LT/GTs.
Old 08-19-2011, 07:49 PM
It certainly is a rough environment for any coating...The best way to protect it IMO is to blow off accumulated grass from the top with an air compressor and remove the deck and scrape away the grass clipping buildup with a putty knife once in awhile. NEVER use water to clean a deck. Avoid mowing wet grass. Just about anything you put on there will wear off anyway.
Old 08-19-2011, 08:07 PM
jbollis's Avatar
jbollis jbollis is offline
What about powder coating, has anyone ever tried to do that ?
Sold everything but one.
