I found a rotary tiller and gear drive for $150. It was a reply to a wanted ad on CL.
He threw some paint bomb on it though. Over spray was in the little utility wagon we got it out of so he must of did it after I called. Now I need to fix up that mess on top of the original mess. I also need to find some info on it like what type and size belts and such. I found the manual on the site for it. Time to study up on it. tiller 1And see if I can get some extenders. He painted over the ID tag but looks like its a 1. Any tips on cleaning the tag off? Will wire brush ruin the original lettering on the tag? Or would some chemical be better to take the paint off? Here are the pictures.
To many ideas, not enough time..... Cub Cadet 147 2050041u340160 Cub cadet 129 main mower Cub Cadet 1811 Cub Cadet 1872 with 60" CCC deck. Many Mower Decks, Snow Thrower, Tire Chains and Weights, Rotary Tiller 1, Brinly Sleeve Hitch, Brinly 10" and 12" plow, Johnny Bucket Jr.,42" QA NF Dozer Blade. |
Try mineral spirits or naptha...if he used really crappy paint, those will take it off. Otherwise, you're pretty much screwed. Any scraping, sanding, etc will also remove the lettering on the tag.
Nice find since it sounds like the paint is fresh, so hopefully it will come off easier like Matt said.
Dale 147-Restored___________________882 Diesel Hydro lift (not installed)___________44" Deck 48" Deck_______________________QA-42a/b Snowthrower Rear lift ________________________XMW cat-0 rear lift Model 2 tiller____________________12" cat-0 Brinly plow |
Congrats! You'll love how great of a job it will do.
Here's some info for you from our technical section of the site.. Belt chart http://www.onlycubcadets.net/forum/showthread.php?t=25 Wild Bill's awesome tiller guide! http://www.onlycubcadets.net/forum/s...ad.php?t=12320 |
Thanks everybody!
![]() I drilled the rivets out. Put it in a dish. I didnt have any mineral spirits or naptha on hand but did have some acetone. So I put a little in the dish and let the tag soak for 5 minutes or so. Then most of it cleaned off with by wiping with an acetoned soaked paper towel. I let is soak another 5 minutes. Wiped some more with a towel and got it all off. None of the original writing appears damaged at all. Now I will just keep it in a safe place until I clean up the rest of the tiller and rivet it back on. Model 1 Serial 3019
Looks like a nice tiller, glade to hear and see the tag cleaned up nice. Definately a Series 1 due to the size ans number of tines. An extension in each end and a good cleaing and perhaps repaint properly will look good as new. Even better if you paint it the correct shade of off white. More I look at things i buy and peope just paint it white...gee whizz!!
Mike Ontario, Canada IH built 982, IH built 782, IH built 782 parts tractor, 100 w/fenders & lights, #4 trailer, 42" front blade, IH 2B tiller, 12" Brinly plow, Brinly cultivator, IH push mower, Sims cab, IH snowthrower, 450 blower. Now everyone wants a Cub! ![]() Beware of the Wife
I'd rather see the wrong color paint than a rusted out mess on something I want. Paint is easier to fix than rust holes.
Amen to that .....I don't care about runs, color match , what ever .....
It beats the heck out of rust ...... I can always take paint off
Great score on the tiller, Larry!
I was given recently a 129 cub cadet It needs complete restore. It come with a 1A U1111 6 tine roto tiller. I found a 3 gblade 42 " mower deck good shape off of a 105 cub cadet. my mule drive has some of the arms cut off. will the mower deck and roto yiller fit this machine. Hornets
| Thread Tools | |
| Display Modes | |
