You guys have been around cubs awhile. Will a trans from an 1864 swap in? (have a slipping problem but trans is way overfull and filter might be clogged..will correct them first)
The number one problem is a bad oil leak from behind injectors. A steady drip. Someone at the auction said it has an "O" ring back there could be leaking. Thoughts? If I can get it lined out I may send my 2182 down the road. The front plastic is junk, but I have the solution to that even if it isn't pretty. |
No, it will not. The 1864 both has a different reduction ratio and a different hydro unit.
Darn, I'll have to cross my fingers on the oil change & filter.
Lets see some more pictures of that cyclops with the 1x6/1x7 grille and hood please.
Nice find on the 1782!
Wow, you just keep finding those diesel's. What part of Illinois are you from? I'm in Plainfield
Dale 147-Restored___________________882 Diesel Hydro lift (not installed)___________44" Deck 48" Deck_______________________QA-42a/b Snowthrower Rear lift ________________________XMW cat-0 rear lift Model 2 tiller____________________12" cat-0 Brinly plow |
Here you go Oak. It's the only other thread I've posted here so far. That will change.
http://www.onlycubcadets.net/forum/s...ad.php?t=13042 |
Yamaguy, I'm in Southern IL at Mt. Vernon..between St. Louis and Evansville. I don't know about this one, but the Kubota powered Kubota was a fluke because no one wanted to tackle the swiss cheese deck. I seem to be getting great deals on cubs lately though. The 1811 was just a really lucky roll of the dice.
Just an update, I did swap the transmission in with no problems, just a brake swap. Gear ratio is probably slightly taller to offset the shorter tires on the 1864. I could see no difference in the pumps.
Driving it, it doesn't seem to have any different ratio, so whatever it is off, it doesn't make any practical difference. I have mowed a couple of times since the swap. It might not swap on paper because it isn't identical on paper but in the real world, it is an easy practical swap. |
Barnabas Collins Nice work, Glad everything swapped for you
| Thread Tools | |
| Display Modes | |
