Update:
Bought new Kohler points and condenser. It fired up better, ran smoother, but eventually the problem came back again after it warmed up a bit. I now believe more than ever that it really just needs rebuilt, no amount of band-aid-ing the problem can compensate for the fact that it burns as much oil as it does gas Ok, that's an exaggeration, obviously, but there's truth to that as well.If I can't find a good used engine that I can afford, she will have to sit until winter, maybe tax return time. ![]() Thanks for your advice guys, really appreciate it. My gut feeling when it first started happening was that it was just time to let her rest, but it's great to have friends to bounce ideas off of before I settled into that ultimate conclusion. |
I feel your pain man my 128 is going too.
1971 128,3pt,ags,rebuilt motor,headlights 1988 1812,dual ports 1966 122,creeper,3pt,ags,sa,headlights,restored 1st place at RPRU 2013 1966 123,3pt,brinly spring assist 1973 108 1968 125 Attachments:QA36A,wfblade,2 nf blades,brinly disc,a cultivator,plow,homemade wrecker boom with 2000lbs winch,ih weights,50lbs weights,2IH windbreakers |
I also am in the same situation with my 1200. It would start right up and run strong as long as I want. But after last mowing, next time I started it up, it formed a blue mushroom cloud for the neighborhood. Now, it sits ready to pull motor out so I can rebuild it again.
104 to 127 conversion with dual 6x12s, hydraulics snow/dirt plow 1200 Quietline 44" mower QA-36 snow thrower |
Hahaha, my poor K in the 129 had the "mushroom cloud" going on for many hours of use before this problem. It was a testament to the integrity of the engine as well as my obsessive maintenance that the engine lasted as long as it has. I think I've been running on borrowed time for the last 100 hours....
I'm still in shock using my 2186 that doesn't use a drop of oil or even think about asking for an oil change after 25 hours. I got so used to checking and changing oil in the K301 that I didn't know what to do with myself! Here's to all of us getting new life breathed into our GTs soon.... |
Well guys , the old girls are giving you the warning that they are tired ....
May be time to react before you put a new sight window in the block ya know ..... |
| Thread Tools | |
| Display Modes | |
