I just bought a 147 and I am going mount a blower on it, but I am concerned about the drive ratio being a little too fast. The tractor needs new tires and I
m wondering if its worth going to a 22 inch tire rather then the 23? Would it make that big of a difference?
![]() With a hydro there is no worry over drive ratio. Ease up on that handle a little bit and enjoy life. ![]() I'm going to move this to the attachment section of the site. |
Changing the tire size will reduce the speed 4.3%.
Considering the 147 will easily go down to 1 MPH, the tire change will reduce the speed .043 MPH to .957 MPH. The 23" tires will give better traction, more than offsetting the benefit of speed reduction. |
Plus with the shorter rear tires, your tractor will look like a 50-60's gasser drag car!
Jeff Brookfield, MO ________________ IH Red 782 with weights and sleeve hitch! IH snow blade, Brinly plow, Brinly disk, Brinly harrow, Johnson rear blade, and a #2 IH Cart |
There shouldn't be a need for worry about speed with a Hydro. I could see a possible need if it was the standard 3 speed. But that is what the creeper drive was designed for.
That probably isn't enough of a change to make a difference in the grand scheme of things because the size on the sidewall and the actual tire height rarely correspond, and there is a lot of variation in height between brands and styles for the same size tractor. A lot of 23" tires are less than 23" tall to begin with anyway.
I wonder what a normal cub cadet would do with super cub cadet gears? How big of a change is it between those too? Im guessing the gear difference is the same as putting 23" tires on a super?
To many ideas, not enough time..... Cub Cadet 147 2050041u340160 Cub cadet 129 main mower Cub Cadet 1811 Cub Cadet 1872 with 60" CCC deck. Many Mower Decks, Snow Thrower, Tire Chains and Weights, Rotary Tiller 1, Brinly Sleeve Hitch, Brinly 10" and 12" plow, Johnny Bucket Jr.,42" QA NF Dozer Blade. |
My 1872 Super goes faster, about the same as putting 26s' on a regular.
So I guess they are geared the same!! |
LarryW- It would be slightly slower. There wouldn't really be a point to making that swap. |
| Thread Tools | |
| Display Modes | |
