Old 10-19-2011, 04:01 PM
Onerook's Avatar
Onerook Onerook is offline
Question Regulator question on '68 model 124
I brought home a barn find the other day and after new tubes, cleaning the glue (probably was gasoline) out of the carb and tank.
Checked wiring for bare spots and traded in the dead battery (punched for 2002 purchase).
Yesterday began the task of trying to get her to turn over with a key.
Found the alternator under the seat and got the diagrams from this forum.
The question I have is that the alternator appears to be for the original Cub. [IE: Bat - Gen - F - L] posts.
According to the service manual, the one for my 124 it should have [Bat - Gen - F - Ground] on the posts.
Will the original work on a 124 w/o lights?
Thanks
Old 10-19-2011, 04:52 PM
Your regulator should not be under the seat on a 124,it should be mounted on the grill casting above the heat shield.Not sure if the reg will work though...never tried using a 4 post on a 3 post cub.Maybe one of our other members will chime in...
Up to 534 and counting...
Old 10-19-2011, 05:19 PM
Onerook's Avatar
Yep mounting bracket and wires are up front [next to the horn *don't know why a horn*], appears like it was taken off and set back in the tool box under the seat
Old 10-24-2011, 08:35 AM
Onerook's Avatar
Default Solution found
It was just a minor wiring change to accommodate the extra terminal.
<Ground> hook to the mounting bolt next to the regulator ground strap
<Bat - Gen - F> all mount normal
<L> Not used
Initial test seemed good and I will know for sure when I get finished with a internal engine once over.
Old 10-24-2011, 08:46 AM
The "Voltage Regulator" you have, will work. Just insulate and do not use the "L" terminal.
Old 10-24-2011, 07:07 PM
The Horn is to warn the DEERE back to the bushes
Old 10-24-2011, 07:34 PM
On my Cubs, you couldn't hear a horn if the engine is at WOT!!!
Old 10-24-2011, 08:02 PM
CHWNY's Avatar
CHWNY CHWNY is offline
You beat me to it
Old 10-25-2011, 03:15 PM
Onerook's Avatar
LOL that's good
Old 10-25-2011, 04:51 PM
I like it!
