Sounds like a plan.
I gave some thought to those winches from Harbor Freight Sam put us on to. I understand that they're not for overhead use but for pulling an engine and maybe a 1,000 pound tractor to the height of a table would work. I don't know, just thinking. Regardless, I ordered two of them with no real plan of what to do with either of them. This of course is Sams fault.
Randy Cubs: 71, 72, 127, 149, 1440, 2186 and 1864 John Deere 110 round fender John Deere 140 H3 Sears: GTV16 |
Yeah, Sam's post got me to buy one as well (does he work for HF???) but I'm talking about this one... http://www.harborfreight.com/1-ton-chain-hoist-996.html |
Yep, I've seen that one a few times too.
I really don't have a good secure, trustworthy anchor point for it on the ceiling. It's all finished and insulated. I would probably just use my 1 ton floor shop crane.
I'm working in my garage and was wondering if putting a hook up in the ceiling was a good idea or not. Not enough room for to much else in a single car garage. Well at least I have options now
It's completely safe been doing it for years. If I run across the situation where the head bolts are sitting below the fins I use a 3/8th spacer and a longer bolt and draw it down tight. Heck the quiet lines already have a lifting point attached to to head using same 3/8 bolt. I myself would opt out of using anything electrical for lifting. If something is binding or jammed up you sure as heck will not know using a pushbutton on an electrical winch. Good recipe to break stuff. Chain falls or come alongs is all I use.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
Good info and I agree about the electric. The link I posted up a few clicks is to a chain based hoist that I was looking at. Seems to be something that is made for stuff like this and not to pricey. Right now I'm just taking my time and getting some great ideas from all you folks as I setup my little shop
I just lifted it out with me and my grandpa. It was a heavy engine (K301), but with the S/G removed it was manageable
They are heavy, I pulled the s/g off my 301 and then picked it out and put it on the bench alone. I wouldn't want many grandpas doing it, but I know a few that still could. Hope I can do it that way for several more years, but if you have any back issues I would sure recommend against it.
73 149, 73 109, 71 128 with sleeve hitch, decks for all with a 44C on the 149 as the daily mower. front blade and IH rock rake |
Thread Tools | |
Display Modes | |
