Capability wise is all I meant. If you had a job you were doing with a 149 and swtched to a 1450 the job would go about the same wouldn't it? I guess you could tell how long it took to complete the job with a 1450
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
Oh. Yes, they are both hydros and both 14hp. I agree with that.
Jonathan do you know what type of Kohler is in it? It isn't a K is it. Doesn't look like it anyway.
K321AQS Yep it's a K series.
Oh ok. Guess thats good because I love the old K's.
No better engine.
Judging by the drippings on the frame and the gas tank on the side, I would say that it has carb problems as the reason why it won't run, but that is a shot in the dark. A 1450 in worse shape than that went for $575 at a local auction and the blade for it went for $150.
Good point bocephus1991 about the rearend. I saw that black hub and thought the same thing. Seems like other members have posted in the distant past about the aluminum rear end and tillers.....not for sure. Let us know if you land it Justin... Cub Cadet 123
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. |
That's what I was getting at, the aluminum rear end housing not being at heavy or as stout as a cast housing. I have both, my 1200 is cast the 1211 is aluminum. All I've ever heard was it is better to have the cast rear instead of the aluminum ones.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! |
I meant heavy as in weight. The aluminum ones are just as strong. Now in tractor pulling, the aluminum gear drive trans are not as strong as the CI ones, but that's a whole different ball game. Only difference between the Al and CI hydro rears is the weight difference.
Thread Tools | |
Display Modes | |
