Those grooves should have a spot of weld tacked in the corners, then filed down to make a nice clean corner. Then install your springs and end caps
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
I plasma cut these out of 1/8" stainless,,, I should have made a couple hundred,,
I think it would be impossible for the spring to wear the stainless,,, especially, considering that it is starting with a plasma cut surface,,, |
Just an observation on the worn trunnion arm, if the spring is centered on the damper plate, it doesn't wear the arm out in the corners. The 1811 had 1500 hours and had virtually no wear. The 2072 had half that many hours and was worn out more (not as bad as some I have seen). The 2072 was not centered and the 1811 damper plate was perfectly centered on the spring.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
Thread Tools | |
Display Modes | |
