The voltage sensor is just a driver for the light. The tractor will run without it. I have a 2165 with a bad engine. I will check the serial number and see if mine has it.
The voltage sensor is something I have not seen on many of the 2000 Series, though all the dashes have the indicator light.
It completes a path to ground for the indicator light when voltage reaches a certain threshold (usually around 12.5 or lower). You should be charging at 13.5-14.2 with the engine running and no load at wide open throttle. The Briggs charging systems are a bit weak, so I'd expect closer to 13.5 with the PTO engaged. If you are seeing proper voltage at the battery but the indicator light is coming on, then you either have a faulty voltage sensor or poor connection to power or ground for the sensor.
http://www.solunagarage.com |
Thread Tools | |
Display Modes | |
