#21
Mine does not have the cradle mod either, so I feel your pain. Completely removing the front axle helps a ton! Between the two front bolts, and leaning over the front tires took way too long to put in 4 bolts.
104 to 127 conversion with dual 6x12s, hydraulics snow/dirt plow 1200 Quietline 44" mower QA-36 snow thrower |
#22
With the front of the tractor suspended, it only takes a minute to pull the front axle pin and get yourself 4" or more of room to work on those front engine bolts. Really the way to go.
#23
So I finally got it done. I had to mill out the bolt holes for the cradle. The slotted holes were at an angle; they would've lined up better if they were straighter. With the creative use of the engine hoist I got the ISO mounts lined up and tightened one at a time. The rest was a bolt on affair. ***Fwiw, buying the new style cradle doesn't bolt right in. The cradle I bought did not use flat stock. It was angle iron. The front tensioner pulley for the mower deck belt actually hit the cradle cross-piece. I had to cut a notch out of it so it would clear.
So, the progress is:
Done for a while. This tractor truly tested my patience and now I am sure I have more money and time into than I'll ever get out of it. But it did fire right up and I mowed the lawn today. And those of you who removed the front axles, smart move. I'm sure that helped a lot. |
Thread Tools | |
Display Modes | |
