Old 04-13-2011, 04:05 PM
JaysNJcub127's Avatar
JaysNJcub127 JaysNJcub127 is offline
Default Compressor motor
Hello all. I just acquired a large air compressor and it's probally between 80 and 100 gallons. It has a duel piston pump. There is a 3 phase motor on it that will have to be replace ld with a one phase. How would I go about finding out what hp etc I would need to replace it with?
1969 Cub Cadet 127
Cub Cadet HDS 2155 w/ bagger
#2 IH cart
48" deck
42" Front Blade
Brinly Sleeve Hitch and Brinly Plow
IH wheel weights
Old 04-13-2011, 04:15 PM
gcbailey's Avatar
gcbailey gcbailey is offline
does the motor have a spec tag on it? I know my dad's 80 gal 3 phase has a 4.5HP motor, it is pretty old so I don't know what a newer one would have or if that's something that has pretty much been a constant.
Gary
Old 04-13-2011, 06:01 PM
Just a thought.
Sometimes retaining the origional 3 phase motor & building a rotary or static phase converter is cost effective if you have single phase 220 Volt power available in your shop.
It all depends on your abilities and just how big a motor that is on it now.
if you are talking 5 hp or more, they can get quite pricy for a 220V single phase replacement.
Old 04-13-2011, 08:56 PM
brentwd's Avatar
brentwd brentwd is offline
You can take a phase converter and convert the power going to it. As for the other, a roto phase will not run the compressor once it has built up pressure. Go with the phase converter. I have made a roto phase for my band saw, but the 3rd leg of the converter is weak and will not run the compressor. I was told this by the guy I got the plans for the converter. I hope this helps.
Old 04-13-2011, 09:06 PM
Default thanks
well, i was looking at phase converters and they seem to be about as much as a new single phase motor. I guess the best way would be to get the spec tag off the motor and have it matched up and see what would work.....
1969 Cub Cadet 127
#2 IH cart
48" deck
42" Front Blade
IH wheel weights
Old 04-14-2011, 07:57 AM
rmunro's Avatar
rmunro rmunro is offline
Advice. Note the motor RPM. I didn't. The 3 phase was 3500RPM, and I replaced with 1750. Worked, but not great. Took another look at the old motor, saw my error. Got a 3500rpm, and, magic.
Roger,,109,1450,1210
Some Days all You Can Do Is Hang On!!!
Old 04-15-2011, 07:51 PM
Default ok
ok Well went to check out air compressor and to my suprise its a 1 phase !!! yay !!! I cant seem to find any info on this motor though.
its a
Fairbanks Morse
Repulsion Start
1ph 220v 6.9 amps
hole mount sk203
number on tag is 439749
and its BIG
1969 Cub Cadet 127
#2 IH cart
48" deck
42" Front Blade
IH wheel weights
Old 04-15-2011, 08:36 PM
its a
Fairbanks Morse
Repulsion Start
1ph 220v 6.9 amps
hole mount sk203
and its BIG
It might be physically big but not in H.P. according to those ratings.
Example:
My compressor motor is 3Hp, single phase, 220V. drawing 16 amp.rated load
Are you sure yours isn't 16.9 amps?
My motor is about 12" diameter and 16 " long, (215 frame) ( 40 yr old Ind. motor)
full of copper windings not these whiz bang china knockoffs.
Old 04-15-2011, 08:41 PM
Default ya
Example:
yes, 6.9 which makes perfect sense for 1hp, what I am reading is that repulsion motors work a little different........ I guess we will find out
1969 Cub Cadet 127
#2 IH cart
48" deck
42" Front Blade
IH wheel weights
Old 04-15-2011, 08:56 PM
1 ph = single phase, is not the same as 1 HP.=horsepower
if it is 1 hp, it is not a " big motor" but I guess it is all in what a person is comparing it to.
Thread Tools
Display Modes
