1772 temp gauge
Anybody know of any good replacement for the temp gauge on a 1772. Kubota still offers one but they want $130. I can't find where the probe is on the engine if there is a probe. From looking at a wireing diagram there is non.
Any help well appreciated.
Charles________________________ 1572 3pnt, rear PTO, 50" deck 1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow 1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow 2072 3pnt 50" deck, Brinly Plow 2072 50" deck Cub Cadet Tank 50 Zero Turn Cub Cadet 33" Commercial Walk Behind 1953 Ih Cub with just about every implement New Holland TC33D with Loader and Backhoe |
I'm sure Oak will chime in, he is the diesel guy here.
It's on the front left corner of the head and it has a green wire attached to it. What is wrong with yours?
The schematic shows a black wire but mine was green. Maybe it faded to green?
My gauge is shot I think the sending unit is still good
I would check with the sponsors at the top and see if they can help. I added aftermarket gauges on mine but had to replace the "gooseneck" where the thermostat goes so that I could mount a temp sensor on the correct side of it. The tap in the head is too small to mount the sensor I had. So far it looks like it's working okay because I mounted the original under the hood with the hour meter. We will see in 11 days at the Bama plow day when it's put to work. I purchased it and the dynamo bracket from Rich Patton and it is from a Kubota D722 diesel engine.
This wasn't hard but it's probably easier to find the correct gauge.
i went with a Sunpro gauge and sensor. the threads in the head are metric and the temp sensor is NPT. i just re-taped the sensor to fit the head. works great. cost me $35 all in.
127 - 48'' deck + tiller. 1512- 46" GT deck & bagger 1872- 60" Haban 1772 turbo diesel- Iron rear + KW loader + backhoe + 3 point. Case 580CK Ford 850 International TD-8E |
Ken do you have more specific info on the model gauge you used and where you got it.
Thanks Chuck
this is the one i used.
http://www.amazon.com/Sunpro-CP7005-...pro+temp+gauge i also got the matching volt meter.
Thread Tools | |
Display Modes | |
