Got the 1641 De-Cyclopsed
Well the plastic on the old gal finally gave up. No more plastic patching for this guy. When I got the 1641 5-6 years ago the plastic pieces were in sad shape and I have been patching,plating and gusseting the panels till there was no more patch left. Decided to do a 82 series retrofit. Still got some small things to do but all in all I'm pretty pleased with how it turned out. Need to fill in the gas cap hole and fab up a grill and install some new canvas for around the hood.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
Looks great! Did you have to do anything special around the Cyclops dash to make the 582 hood fit properly? Were the side panels a direct fit?
Thanks for posting. pics of the process would be great if you have them
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
Jay I had to trim the lip off of the dash with a cut off wheel so the 582 hood would sit flush on it. Moved the grill back approx. 1 1/2" and removed about the same on the hood where it sits on the dash. Trimmed about 3/4" off the front of the side panels to get the correct length. Cut out the sides of the plastic dash so the side panels would fit up against the dash tower. Had to notch out a spot on the left panel so it would go around the hydraulic hoses. The right side panel I was able to use the original mounting hole and drill a hole in dash tower and the left one I had to use a different area on the panel to mount with.
Nice work! Looks excellent. Like red.
Red is for the blood we shed!
Tankman '95 CCC 1641 Eastern PA USMC |
Thanks Tankman.
Nice work. Going to get some custom decals?
Nice work on the sheet metal, are you going to try and put the 82 rear fenders on also?
It looks really good.. nice work!!
johnhall doubt if i will decal it because the only action it sees is snowblowing. Thanks for the compliments guys.
Nice job Kelly. I'd like to see some close-up's of the transition around the dash tower when you get a chance.
Thread Tools | |
Display Modes | |
