Newbie Tips Needed
I got my first cub a short time ago. It is a 2284 that came with the 451 snowblower attached and a cab enclosure. It was be primarily used for snow removal.
Before winter hits I want to take the cab and snowblower off to get more familiar with it (I am not the most mechanically inclined person but I am learning). It appears I need to undo the hydraulic pole, loosen the tension of the belt pulley, and then it is just 2 bolts. Any tips/tricks for removing the 451 snowblower? |
I wouldn't mess with removing anything! Plenty online you can read to learn more, or if have questions ask here! But I wouldn't monkey with it unless something is broken.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! |
Here are some links pertaining to the Cyclops series.
http://www.onlycubcadets.net/forum/s...ad.php?t=33244 Congrats on buying the last of the best.
I know, part of me wants to just leave it until spring, but I at a minimum I want to be able to remove/install the cab, snowblower, mower deck, and do routine maintenance.
Thanks for the links! I will check them out. |
It's a lot of work to remove both. Best just to wait until it's necessary, then learn. Unless you just like to cuss a lot and work hard for no real reason.... Not that a lot of cussing is necessary, but the blowers are a real pain to remove just because they are awkward and heavy. After doing it a few times, you'll get a pattern. Cab.... I like to just leave it on unless it really, really needs to come off. |
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
Great minds think alike. I made a little "pallet" on wheels for mine. Works awesome. On concrete..... |
I dream for the days when I can use concrete!
This manual should help. Can download from MTD manual website. Use 190 451 100 as model number. Can't remember if supposed to have spaces or hyphens between each set of three numbers. You can also call the tech line and they will email them to you. The form number is helpful for the MTD folks also. 772-9068 is the owners manual for your 2284. 772-4166 is the form number for a massive 400+ page service manual for the Cyclops series tractors with sections on implements also. That manual will help perform some much needed service to your 20+ year old snow eating monster. Great tractor and great blower. Would be real nice if you did not need them at all this year..... Oh and
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights. {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
Thread Tools | |
Display Modes | |
