Kohler Command muffler
I have two Command engines that have the baffles and/or tubes loose inside the muffler. Lot's of rattling around. I'd like to cut open the muffler and remove the loose pieces.
I know I need to cut a hole someplace. Just not sure where. Anyone have any useful tips for this? |
It's looking like I am the only one to have this problem?
Uncrimp the left end on one, if that does not work, uncrimp in the other one on the right end and see what falls out.
Yeah, but I'm afraid if I do that, I can't seal the ends back on to be leak free.
I'm thinking cutting a 1 1/2" 2" hole in the end would be a little cleaner deal if I knew where to cut. |
I gas weld the ends when they break/ rust or blow out on the opposed twins,
-------Works for me. A mig usually is unsuccessful on thin rusted metal. |
Well, that helps. I was going to use a Mig to close it up. Been a long time since I gas welded. I was thinking more along the lines of using a hole saw, in the right spot and cut hole of some pre-determined size and location. Then, cut another patch slightly larger and close the hole up with a Mig. I'm not in a hurry to pay CC's price for a new muffler. |
Which model command?
Command as used in 1860-1864.
Thread Tools | |
Display Modes | |
