PTO Clutch Will Not Engage
My Quietline 1200 suddenly decided the front PTO for mowing blades won't
turn on. Flip the dash switch and nothing. I checked under the dash and the two plugs were attached. I checked the two fuses on the dash support and one was warm! I sprayed contact cleaner on the switch under the dash and at the dash. I checked the connector at the side of the PTO and its connected. Nothing. Any ideas? Thanks! |
Unplug the PTO at the PTO. Jumper 12v to the wiring of the PTO to see if it pulls in. If not, check continuity of the PTO coil. If open, time to change the PTO.
Try jiggling the pto switch when sitting in the seat with the engine running.It may work.
i will try the jumper suggestion first. i have 3 quietlines i mow with weekly and i get the jiggle the switch but on this one(1200) it does not kick on.
i will need to research the electric continuity thing. i am way more mechanical than electrical. thanks for all the input and suggestions. I rely on you experts so much to keep my mowers working ! |
Use an ohm meter. Should have between 3 and 5 ohms from connector to ground.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
If electrical checks out, maybe check and see if it needs to be tightened up. Cant recall what size feeler gauge to use, .15 maybe, could be its worn and needs adjusted.
I did the jumper wire direct to the pto and "click" so it was good.
I disconnected the wire plugs from the switch on the dash, removed switch and cleaned it with spray electrical contact cleaner. Re installed switch, connected wire plugs and BINGO! its works. Thank you all for all your suggestions. You guys always keep my cubs working for me(all 3 of them!) |
Thread Tools | |
Display Modes | |
