Old 12-14-2020, 11:25 AM
Userj8670's Avatar
Default Cant get snow thrower belt to hold tension
Put a brand new snow thrower belt on the wideframe 169 and (for the QA42A) can't seem to get the pulley to lock down and hold tension on the belt. I am able to move the pulley up and down by tugging on the belt.
Please see video below for a better idea of what my issue is.
https://youtu.be/qX6-Xht5Mss
What am I missing lol - can't be that difficult
Thanks!
Old 12-14-2020, 12:13 PM
Inactive Member
Do you have the Installation Manual and looked through it? See link:
Installation Manual
Old 12-14-2020, 08:05 PM
Turn the 'TEE' handled screw to tighten the belt, assuming you have the correct belt.
Download the manual for the thrower.
Old 12-14-2020, 10:20 PM
Userj8670's Avatar
Installation Manual
Thanks Roland. I do have the manual but it doesn't cover or go over the issue I am experiencing. Upon further review, it seems the T handle/screw has come lose. The nut on the opposite end is no longer holding it tight thus causing play. Have to try and figure out best way to tighten it up as it's pretty frozen.
https://www.youtube.com/watch?v=Kzgj...ature=youtu.be
Old 12-15-2020, 05:19 AM
You need to free up the nuts on the screw and it will tighten up as designed.
Remove the cotter key and apply a little heat to the serrated nut and the nut on the end of the screw.
Remove it and clean up the treads on the screw with your wire brush, reassemble w/a dab of never seize and adjust.
Then drill and tap a 1/4" hole in the side frame just above the TEE handle when it is adjusted.
Screw a nut on a short bolt ling enough to extend past the tee handle and screw into the newly threaded hole, tighten the jam nut against the side frame to secure it. This will keep the handle from working loose.
Old 12-15-2020, 09:02 AM
And if things get out of hand and yer nuts are rusty, worn or the threaded
rod is bad,
Jeff makes left handed treaded adjustment assy, or just the threaded nut/rod
See top of page header "parts by jeff" scroll down maybe 4 or 5 pictures
Did I mention I hate snow?
Old 12-15-2020, 10:01 AM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
Now hold on a second, that ain't your line!
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 12-15-2020, 10:43 AM
Ah, yes it is it!!!!!!! is disgusting, evil and plum kold.
it makes things break, not only mechanical, but physical when one makes bodily contact with it in a clumsy fashion.
Nope, I hate snow.
Ice is right there with it, but it is more apparent, snow is sneaky.
End of story.
Old 12-15-2020, 11:33 AM
Nope, I hate snow.
End of story.
hmmm, in that case, you certainly aren't the only one!
Kinda have to agree, not much fun when it's so cold out that you can't get any work done.
Been lucky around here, the Upstate NY winter hasn't set in yet, but it's just a matter of time
But hey, before I know it it'll be spring again and I can get back to workin'
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 12-17-2020, 09:24 AM
Userj8670's Avatar
Took the T off and it's a wonder how it ever worked previously as the nut couldnt be tightened any farther then where it was due to lack of threads on the T. Further examination indicated that the area in question was never threaded previously.
Added some washers to take up the slack but still doesn't fix the issue. Temporary band aid until I can further assess.
Cheers!
Thread Tools
Display Modes
